what else to get to cut 60 ft time
Again I'll ask, should I do v6 springs or hal's or torque arm next?
Ladder bar cars are similar to torque arm cars.
my car consists of a stock unmodified torque arm, my relocation brackets, Wolfe double adjustable chromoly LCA's and a Wolfe Drag bar. I have a yank T400 X-member for the trans. I have a stock panhard rod, with eibach lowering kit all around and the original hal shocks and springs. Front springs are also pro kit.
NOT a chassis expert, but I have been playing with my '94's suspension and going to the track regularly with it since begining of '96.
Don't know about the relo brackets. Had a guy who knows what he's doing install them for me, but they didn't seem to help my 60' much if at all.
I would say that for weight transfer, the biggest difference was installing QA-1's up front and V6 springs out back. After that, my car would lift the tires a few inches on measley 1.70 short times. Doing those gave me weight transfer like a *****.
I am finishing up my big conversion on my '94 that chiefly revolves around the installation of a 385 LT4 motor. I'm about to install a Wolfe Racecraft rear sway bar and then hit the track. Should see some serious wheelies now.
Think I will go with maybe a 3500 stall with like a 2.2 str from Fuddle. I didn't realize you're running only a 2600 stall.
My relocation brackets do exactly what you are saying..ive got video of it from a few years back...
watch the end of this video.
http://www.motr.biz/beenfetched_2.wmv
Nice shot.
The body on ours stays at the same level as before the launch, just our axle hits the ground hard, then as the tires spool up (wrinkle the tire wall) they lift the axle from the ground ... causing the axle to rotate upon the axle shaft centerline, lifting the front end.
When you want a good set on the car Eric hit me up...The ones you have on there now are junk but better then none at all.
Mike
Hey hutto you still selling those piece of **** brackets?
