Any issues with your Aerospace brakes?
Thanks,
Eric
Nate
Did you shim the caliper so its centered over the rotor?
Bleeders on top? well bled?
What part is hitting the rotors?
I know the install instructions are pretty vague but honestly I am more then happy with these on both cars.
So I started with the pass. side and everything looked good. Pad wear looked even, pistons seemed to be protruding and retracting into the caliper evenly, etc. When I got into the drivers side, I immediately noticed some gouging of the rotor due to contact with the caliper in two places. Also, I noticed that the pressed in threaded inserts in the brackets that hold the caliper were being pulled slightly out by the bolts that hold the caliper to said bracket. This would pull the caliper towards the inside fare of the rotor. (KP mentioned a good point about shimming the calipers to center over the rotor, I did not do that. and looling at it, I'm not sure how you could.) Judging by the gouging of the pads and rotor, some of the billet aluminum from the caliper got between the two and tore into it pretty good. Also, with the pads removed, I push on the brake pedal to get the pistons to come out and I noticed that one of them seemed to come out farther than the other. I don't think this would have anything to do with the rotor hitting the caliper but it could explain why the front brakes/line lock won't hold the car. Now, with all that said, I still don't know why I can't get any pedal! I have some good pictures but I don't know how to post them. Maybe I could email them to someone and they could post/host them if people wanted to see them.
Daren
What happens when the caliper isnt centered is when you apply the brakes it will bend the bracket over and when you let off it the bracket returning will push those pistons back in and you will never get a good hard pedal since the pistons are pushed back in when you let off them.
ANY race brake since they are low drag you will lose some pedal on the first press, and if the rotors run out some the pedal will feel even lower on the first press since the pistons are getting pushed in bt the rotor wobbling some. After a while you will learn the 'quick pump' the first time to get the pedal up higher but its not really necessary. Thats how drag race brakes are, if you want a perfect stock pedal leave the stock brakes on
Anyhow you can see the thin washers used to center the caliper between the caliper and spacer in this pic and how the bracket needs to be so the inserts dont pull out. I pulled a wheel off just for you guys, if the bracket is on the other way the caliper will pull of the bracket eventually..
Besides the weight/friction you can also bolt any 15" front drag wheel you want on the car without spacers/grinding which is nice.
GM Muscle, those are metric ARP front wheel studs, they are not included. These pads work fine and I dont know whats available for different compunds, I drive mine quite a bit and they are hardly even worn. They are a little noisy though but these dont have any anti-rattle hardware so expect some odd noises..
I thought dyno #'s might increase, but they didn't either.
Its a pretty simple install, no 'tricks' really. As long as it looks like the pic I posted thats pretty much it.. I use a 5.00 advanced auto 'one man' brake bleeder and it took like 15 minutes to bleed them.
With what came with the kit and the not-so-descriptive instructions, it's the only way it would even come close to lining up. I had to go to the hardware and pick up some washers as I didn't get any extras with my kit. I gained some clearance by doing that. It was only off center a little but apparently it was enough to cause the rotor and caliper to touch. I put it all back together and took it around the block. Pedal feels the same. The brakes will only engage in the last 7/8th's of it's travel but it does seem to stop a little firmer. Like KP said, they are race brakes and are not going to feel like stock. I am going to manual brakes this winter so we will see how they feel then.Looking at the situation a little closer, I think this is one of those common occurrences that pop up when a novice like myself really begins to transform a car (especially a car like a 4th Gen F-body that hasn't been around that long, unlike say a '69 Camaro or a Fox body Ford that have years of after market support) into a "race" car and leave the safe realm of the "bolt-on" parts world. As a credit to this site, and the people who post here, since 2002, I have been able to put together a low 11 sec. car entirely in my garage (except for tuning) with no real previous experience to speak of and a "relatively" small amount of money. I guess I'm just throwing this out there for the guys that were in my position a year or two ago to let them know it can be done and you don't have to have a unlimited budget to make it work. A lot of credit has to go to GM and the LSx based engines for giving us a hell of a starting platform!
Oh but in my defense, the directions were kinda sucky!
Thanks again for the insight fellas.
Eric
I'm sure you will get used to them quick enough.If you pump the once quick it should get a little firmer but you wont get that hard as a rock stock pedal on the first push. When I put the strange brakes on the rear the pedal got pretty mushy but it still stops fine - just takes some getting used to.
I had a manual master on my last car and wasnt real happy with it, it was OK on the track but I was always afraid I was going to rear end someone on the street. Yes I drilled the brake pedal higher to get more leverage
I have driven plenty of 'real' manual brake street/race cars and they stopped way better then than that one did, maybe it was the stock rear brakes but trying to stop quick at like 40mph was a little scary. I would leave the power if you make enough vacuum to run it and you street drive a lot, the booster doesnt weigh much at all.
