Need help with cam only car issues....
Sux2bu, some of the people making the larger cams are warning people that the drivability isn't that good.. but I'm thinking more along the lines that if the cam's not going in a suitable car... don't even offer it to them, offer something that will work, unless you have someone that is dead set on turning their car into a tin can to race it.
I'm not claiming to be a genuis, nor do I have and creditability for my thinking on this.. but guys that have street cars, should get something in the 220 to 230 range ( say a 222/227, or a 226/230, no more then that, and something in the high 590's for lift.. this would give them the power increase that they are looking for, and be very user friendly, still get acceptable gas mileage, and not turn their car into a literal turtle until 30 mph is reached.
Wanna car that comes on about 500 feet out of the gates.. get a turbo supra or something. We have V8 modern american muscle cars.. manufacturers should be reccommending stuff in the power department that will help their customers heavy full weight car pull the fron tires off the ground out of the gates... that would be a better approach rather then tossing in the biggest cam that can fit in a stock motor. so the car can start to pull at 4500 rpm.. where everyone drives around at all the time on the street.
If you want to get a good time out of M6 you HAVE to launch it like you want to break it. you can't leave on 3000 rpms, feather the clutch and expect to run a decent time.
