Drag Racing Tech
Thinking motor plates...
Old Oct 3, 2005 | 10:26 PM
Drake's Avatar
Default Thinking motor plates...
Who still sells these? I know about Madman and Stenod, anyone else? I guess making my own is an option, but I haven't researched how to do that. Anyone running plates now, please chime in on how they change the overall behavior of the car.
Thanks!
Old Oct 4, 2005 | 02:17 PM
Drake's Avatar
To The Top
Old Oct 7, 2005 | 09:23 PM
WILWAXU's Avatar
Lets try this in the Drag Racing Tech section.
Old Oct 7, 2005 | 09:38 PM
liftin'em on nittos's Avatar
why are you wanting to run a plate?
Old Oct 7, 2005 | 11:01 PM
camrsz's Avatar
I got a plate from KTS racecars.every bolthole was dead on. Even though it was made for 4th gen f bodys I made it work for my 73 camaro. The plate is very nice. Sorry I dont know how it makes newer f bodys feel.
Old Oct 8, 2005 | 05:23 AM
oOoLy's Avatar
I got my plate from Dave@KTS for my car and it's nice plate
Old Oct 12, 2005 | 05:43 PM
Drake's Avatar
Thanks for the info guys, I'll give KTS a call. I emailed them, and Stenod, but they never replied.
Old Oct 13, 2005 | 06:37 AM
oOoLy's Avatar
Try to send PM !!!
Old Oct 13, 2005 | 09:55 AM
Hawkn01's Avatar
Thanks!
I have what your looking for. Sent you a PM.
Old Oct 13, 2005 | 10:17 AM
Drake's Avatar
Replied, Hawkn01...
Also, Liften'im, I'm planning on running the motor/mid plate setup for ease of removing the engine, fixed motor placement for turbocharger plumbing, and structural rigidity of both the car and engine.
Old Oct 13, 2005 | 04:36 PM
mongse's Avatar
I ruin the end of films...
Every drag car I build from now on will use them. Wish I had went w/ them in the TA right off the bat.
Old Oct 13, 2005 | 09:03 PM
what are you guys with them doing about the mid plate thickness? milling that off the bellhousing?
Old Oct 13, 2005 | 10:18 PM
Drake's Avatar
Matthew Harlan was kind enough to suggest using longer bellhousing dowel pins and bolts. I'll figure it out when mine comes in.
Old Oct 13, 2005 | 11:04 PM
CMSDave's Avatar
Whoever makes the converter can add length to the hub and mounting pads.
Or if you already have the converter, you can mill the center hub and the mounting surface pads of the flexplate down, at least on a TCI FP you can.
