Drag Racing Tech
Anyone know the th400 driveshaft length with...
Old Oct 6, 2005 | 02:36 PM
xssive's Avatar
Default Anyone know the th400 driveshaft length with...
Anyone know the th400 driveshaft length needed when using a short tailshaft and a stock 10bolt rearend? I would need the u-joint center distance...
Old Oct 6, 2005 | 03:17 PM
Sandmann120's Avatar
I'll try to measure mine tomorow.
Old Oct 6, 2005 | 03:46 PM
BKHAWK1's Avatar
If i am not mistakeing, there is NO cutting involved if you use a short tail.
I wish i would have known that before i used the long tail.
xssive's Avatar
Yeah you actually need a longer driveshaft with the short tail...
Old Oct 6, 2005 | 04:01 PM
BKHAWK1's Avatar
I can't believe you are still on the stock rear and going with a TH400. My rear broke Way before the A4 did.
Are you going with a steel or aluminum DS? or carbon fiber?$$$$
I cut the Stock aluminum shaft and still use it for weight reduction, and i had a steel shaft made for a spare.
Never mind! I just read your sig. I see your going turbo. Sorry.
