what kind of light weight batteries??
what does it way? is it side post? top post? or both?
thanks.
Does it work OK with the stock alternator?
Here's the one I have.
http://www.gotbatteries.com/items.as...SL105/37L105S5
Here's a list of all the hawkers and their specs.
http://www.gotbatteries.com/products...es/Odyssey.asp
BTW: The PC925 is a great option too, it's 25lbs though.
Same as the Dynabat for half the cost.
), stock stereo, AC, Lights, and I power my laptop from an inverter as well as wideband, occasionally a manual low speed fan switch with the car in the pits. NO ISSUES YET. I love it, small, compact, lighter by a long shot. Like I said, I will order the terminal lugs, they screw into the batt. and then you can use the stock hardware with rubber boots. Good luck and you'll enjoy it. anything to loose some weight!!
thanks for the imput.
