What PSI for ET Streets??
Originally Posted by pontiac
well I have to fix this **** 1.76............60 foot
2-step set at 5800, 4.11 gear, and still bull **** 1.7 I think my wheels are spinning in the tires
its gonna be harder for you because you are an m6. the mt dr will stick A LOT of power to the ground...but its still a drag radial and there is a point where it cant take the shock. there is a technique to launching a stick car on a dr that you need to learn. i just dont see laying it on a 2-step and dropping the clutch the way to do it.
Another C5 owner here. 26x11.5x16 running anywhere from 9-12 lbs. Never had a problem on the big end with the pressure that low. Off the 2-step I've been cutting 1.5x consistently with 100% stock suspension, just lowered it some.
