Drag Racing Tech
How to heat up slicks?
Old Nov 1, 2005 | 02:16 PM
Starz T/A 17's Avatar
Default How to heat up slicks?
I just got a set of slicks and was wondering the proper way to heat them up. Do you roll through the water or spin them in the water? Also my cars a M6 so whats the best way to start spinning the tires w/out screwing up my clutch? Know alot of this is stuff you have to learn from experience but would like to have an idea of what to do before I go...
Old Nov 1, 2005 | 02:32 PM
JustAnIlluzion's Avatar
roll back into the water, get some water on them, then roll forward, then spin them. with the manual just drop the clutch at a higher rpm in first and it should do the trick
Old Nov 1, 2005 | 04:48 PM
paper doll's Avatar
i'm with him , pull around the water then back into it, make sure to keep the front set dry
Old Nov 2, 2005 | 10:06 AM
1fastWS6's Avatar
Get a line lock......you will likely fry your clutch w/o one.
Old Nov 2, 2005 | 03:26 PM
My clutch is still stock... Would there be a good way of going about heating them up, Going Friday so I wont have time to get a line lock. Any suggestions or would I be better off not heating them up?
Old Nov 2, 2005 | 11:56 PM
Mike K.'s Avatar
some people although I would not like to do it pope the clutch in first or 2nd and then hit the brakes so it kinda acts like a line lock except you are wearing on your rear break pads.
Old Nov 3, 2005 | 01:13 AM
silverZ98's Avatar
hope you dont have the stock rar in there running them slicks
Old Nov 3, 2005 | 08:57 AM
Thanks Ill probally try that, if not just run them w/out heating them up
And yeah I do have a stock rear, dont plan on launching too high
Old Nov 3, 2005 | 01:22 PM
CMSDave's Avatar
I've always dumped in second w/o a linelock.
If they're new tires, they need to heat cycle thru 2-3 burnouts, so make them count.
Old Nov 3, 2005 | 04:45 PM
02 Camaro SS's Avatar
The guy it the pits at Island Dragway told me to get my rear tires in the water and do a quick spin in to get the whole tire wet. Then roll out of the water and do the burnout (I do it in 2nd gear and have a linelock)
Old Nov 3, 2005 | 11:52 PM
Thanks guys headin to the track friday night so ill see what I can do
Old Nov 4, 2005 | 02:55 PM
EviLS1's Avatar
It's not the clutch you will fry, it's your rear brakes that takes the damage when coming out of a 'powerbrake'
Old Nov 4, 2005 | 03:02 PM
02WS6Bird's Avatar
you should be able to feel the tires grab... if necesary go do a dry hop or something if your unsure
Old Nov 4, 2005 | 04:10 PM
Thanks guys really appreciate the advice
