Skinnies
VIPRETR2: Why even risk it? Just run the 3.5 skinnies and if the LT1 brakes are smaller you might be able to get away with not grinding anything and no spacers. the 3.5 have WAY better clearence so i can't understand why anyone would run the 4".
I would NEVER put any spacers on any car i owned with stock studs. seen a couple of wheels fall off because of this.
HONESTLY!Also, with the Centerline Convo Pros and Telstars 4-inchers I haven't had to use any spacers or grinding whatsoever. But with the Weld 3.5inchers I had to use a 3/8" spacer.
