BMR Xtreme duty torque arm questions
Ok...the install is done. Compared to my recent Spohn torque arm, the BMR seems to higher in the front. It runs parellel to the driveshaft and everything is square, its just the nose of the torque arm where it bolts to the crossmember seems like its higher. Anyhow, since its higher, is the pinion angle going to be different? The reason I ask is because my Spohn torque arm sat pretty level as the BMR is point more upwards. If I'm measuring pinion angle alone, its a zero, but if I do driveline angle, then its at -2. What do I do about that?
Also, with a higher front mounting point, does the car want to wheelie less or more?
Thanks.
Thanks.
FASTEST ALL MOTOR LS1 IN THE COUNTRY
id give jay billingsley a call at the shop he will get you squared away.....or you can send him a pm......btw on my car jay only wanted to run -1/2.....with the bmr extreme t/a
