Drag Racing Tech
Skinnies and Meats question....
Old Nov 25, 2005 | 07:55 AM
TNTramair's Avatar
Default Skinnies and Meats question....
are there any available that i can run without having to grind the calipers to make em fit?? if so, what size to run.
time to throw on some meats and skinnies and see what this thing is supposed to run down the 1320. id like to see atleast a high 10 if i can keep the rear together for 2-3 runs...
Old Nov 25, 2005 | 11:36 AM
Bryan @ Speed Inc.'s Avatar
bogarts will fit without grinding... just go get a $30 grinder from home depot and git'r done. buy some welds and get a 5/16" spacers. it's not that bad if you have the right tool.
Old Nov 25, 2005 | 10:26 PM
ChevyZ28Thunder's Avatar
Just grind and dont worry about it. I went Telstar's which require the most grinding. The front calpiers did not take much grinding. The backs well...
If you have the money for Bogarts then by all means buy them.
Old Nov 25, 2005 | 10:38 PM
glennster's Avatar
convo pros don't require any grinding.
Old Nov 25, 2005 | 11:37 PM
So true. Just like the telstar look myself. And no spacers here.
Old Nov 26, 2005 | 07:28 AM
TNTramair's Avatar
thanx for the help guys.
Old Nov 26, 2005 | 07:57 AM
weaponZ's Avatar
i got 15x10 weld prostars and had to gring the rear calipor's so deep i was worried if they would still stay togather.i heard the 15x8's only require a little grinding.i also think i have a 3rd gen. offset,because they stick out alot.we put them on my buddys 3rd gen too compare and they tucked nicely.
Old Nov 26, 2005 | 12:15 PM
00SS4780's Avatar
Those telstars do look great man! I didn't know if they required grinding or not.
Old Nov 26, 2005 | 02:45 PM
Cheater's Avatar
it's not half as bad as you think
