Drag Racing Tech
Coil Relocation locations
Old Nov 25, 2005 | 04:05 PM
mattr228's Avatar
Default Coil Relocation locations
Looking for different ways to relocate the coils. has anyone mounted them in a different location than underneath the cowl?
pics would be greatly appreciated
Old Nov 26, 2005 | 04:58 PM
Gimp98TNT's Avatar
I mounted mine on the frame rails, had to delete the ABS unit on the drivers side, and the AC and the traction control motor on the pass. side. All of that stuff was gone a long time ago. I've got some pics but there too large to upload to the site, i could send them to ya if you want them.
Old Nov 28, 2005 | 01:30 PM
Brandon Boomhauer's Avatar
host them someplace like photobucket or tinypic.com
or email them to me
bauer.brandon@gmail.com and i'll host them for you
Old Nov 29, 2005 | 12:03 AM
Gimp98TNT's Avatar
here they are.
Old Nov 29, 2005 | 12:04 AM
Gimp98TNT's Avatar
another one
Old Nov 29, 2005 | 12:05 AM
Gimp98TNT's Avatar
last one
Old Nov 29, 2005 | 12:13 AM
mattr228's Avatar
that looks really good , and what i was looking for
you still running the stock PCM?
if so did you have to extend the wiring harness ?
Old Nov 29, 2005 | 01:01 AM
Gimp98TNT's Avatar
yes, still stock PCM. Yes I had to extend the harness.
Old Nov 29, 2005 | 02:39 AM
mattr228's Avatar
did you make the extension yourself, or does a company out there make them?
Old Nov 29, 2005 | 08:37 AM
xssive's Avatar
https://ls1tech.com/forums/lsx-parts-sale/415645-coilpack-harnesses.html
Old Nov 29, 2005 | 08:44 AM
Big Mike's Avatar
I've read and heard that the further you bring the coil away from the motor, the more current you loose. Kind of like when you run too much extension cord when you use a power tool and the tool seems weaker. The shorter the plug wires the better. Can some one verify this?
Old Nov 29, 2005 | 08:57 AM
Carbed4thGen's Avatar
Wat your saying seems true. If you think about it. More wire equals more resistance which equals less current flow in the end
Old Nov 29, 2005 | 08:59 AM
~JOSHUA's Avatar
I've got mine mounted under the cowl. I wish I had photos available. I made the brackets out of all-thread and 1/8" polished aluminum strip. Since the harness is so close to the stock location it didn't need splicing/extending.
Old Nov 29, 2005 | 03:38 PM
gearheads78's Avatar
I wouldn't worrie about that. Traditional motors only run one coil and wires longer than that. I would be willing to bet there is 0 power loss since there is a coil for each plug.
