Pics of my homemade Subframe connectors
Made my own subframe connectors around 2 years ago..
2 X 3 Mild steel..... slide into front and rear subframes.. fully welded.. it was a big project.. but car is solid....
finally found a pic.... 2000 Z28
http://i29.photobucket.com/albums/c2...E/subframe.jpg
yes through the floor...
thanks.. i will try and get some pics from the inside.....
the car wont bundge if only on a jack stand in left rear and right front..
LIKE A ROCK....... added weight but solid... along with the cage
thanks alot guys.... it was alot of work, but worth it...
it was scary cutting big holes in the floor pan... all the contours make it hard to measure..
but they turned out good... ill try to post some pics from up top eventually..
Dave
Dave
