MT DR's and no traction WTF???
-William
i have hals all around, sphon ta, lca, panhard, relocation brakets set to lowest, and im on 255/50/16 etstreet radials.
at 16 psi they wrinkled and hooked like crazy with a nice 2ed gear burn out leavin at 5500. i then tried 14 psi and a 600 launch and it launched even harder and lifted the wheels even highr hahaha
i will try a higher psi next time just to see but for me a heavy burnout in 2ed gear is the way to go
i called up madman because i had bad wheel hop with my setup even with the sphon stuff and the brakets. he told me that it was the shocks...and he was right. the rear shocks were done after 3 years of constant hard shifts and even more so now they they had to control a 12 bolt now. no i have no more problems and i dont see how it could bind. basicaly the ta and the lca are already causing the rear to "bind" by stoping it from rotating up...i ahve no problem like i said
