Drag Racing Tech
Lightest trailing arms?
Old Dec 30, 2005 | 09:04 AM
12secondv6's Avatar
Default Lightest trailing arms?
Currently I have:
Old school boxed hotchkis trailing arms.
I put them in the bird back in 1998!!!!
Monster sized.... huge and heavy.
Bird is at 2848..... and soon to lose heat and several other things.
Now I'm looking elsewhere.
I'm figuring some type of chrome moly trailing arm would be best.
Adjustable would make a bit more sense for trial and error for launches.
Anyone ever actually weigh theirs?
Anyone know the lightest ones out there?
Thanks in advance!
Old Dec 30, 2005 | 09:11 AM
Damage Inc.'s Avatar
Sweet Cheeks
When I think light I'm thinking BAD Z's aluminums or Billingsley's Moly.
I'm running Moly BMR adjustables, but honestly, I think any tubular chromoly LCA will be close to another.
However, some true weights will make this a great thread and we can update the weight reduction sticky.
TTT.
Old Dec 30, 2005 | 10:03 AM
csjta2's Avatar
Check out wolferacecraft, they are also on sale!
Old Dec 30, 2005 | 10:26 AM
CAT3's Avatar
Restricted User
I cant comment on the Madman's, but from all other accounts, BADZ's are the fricken lightest I have ever seen. I would recommend replacing the ends with genuine QA1 though, the supplied ends rattled after 2hrs or so of driving. QA1 replacements been on 8 months of abuse, quiet.
Old Dec 30, 2005 | 04:09 PM
The Juggernaut's Avatar
LG's aluminium LCA's are 1.46# each.But you need to run some sort of anti roll bar.
Old Dec 30, 2005 | 04:58 PM
gator's 99TA's Avatar
did you just say 1.46 lbs?
Old Dec 30, 2005 | 05:04 PM
Yes sir.Under 3# for the both of them.
Old Dec 30, 2005 | 05:19 PM
smoknta's Avatar
The stockers on my 93 TA were about 4.3 lbs a piece. I just got done making a set of Chromemoly adjustables w/ rod ends. The weigh in right around 3 lbs a piece. Here are some pics:
I personally dont have any experience with aluminum control arms, but I dont think they would compare in strength and rigidity to a set of chromemoly. I dont think they would break, but I bet the flex a lot under hard launches.
Attached Thumbnails Lightest trailing arms?-100_0707-resize.jpg   Lightest trailing arms?-mvc-001s.jpg   Lightest trailing arms?-mvc-005s.jpg
Old Dec 30, 2005 | 05:26 PM
GM Muscle's Avatar
I run the aluminium Bad Zs too. They are pretty damn light and my rod ends are still quiet even after two years.
Old Dec 30, 2005 | 07:57 PM
chpmnsws6's Avatar
i actually have a set i got off of "trackbird" they have been thru hell and have come back to tell about it
Old Dec 30, 2005 | 08:49 PM
Shon Herron's Avatar
Mine are 4# each, same as stock.
see www.herronperformance.com to view (I am not selling them anymore so this is nto unpaid advertising.) Just for reference. But can give you all the part numbers needed if you want to make some.
But found it much cheaper to buy from others...ie SJM and some others....
Old Dec 30, 2005 | 11:52 PM
Sweet Cheeks
What do Moly BMR adjustables weigh?
Just wondering for comparison reasons.
Old Dec 31, 2005 | 08:51 AM
CAT3's Avatar
Restricted User
Your site says yours are 33% lighter? Look similar to BADZ, but I am sure the BADZ arent 3lbs each? Anyone weigh a set?
Old Dec 31, 2005 | 08:55 AM
33% lighter than another brand of LCAs I had that were poly ended.
For those companies making the Rod ended ones, not sure how they are getting them lighter than 4#s each b/c the ends are the heaviest part.
Old Dec 31, 2005 | 05:23 PM
SJM Manufacturing Inc's Avatar
Stock LCA is 4 lb 8.5 ounces.
Our LCA kit is 2lb 11.5 ounces...this is WITH the rod ends.
We offer our LCA's in either standard or custom offset for wider tires. We use ONLY high-end QA1 rod ends (most everyone does on this board now)
As mentioned above, ours are competitely priced.
Steve
Old Jan 4, 2006 | 05:03 PM
383ss's Avatar
I swapped from the exact hotchkis LCA's and panhard to Billinglsy Panhard and LCA's and saved 27lbs!!! I couldn't believe it.
Old Jan 4, 2006 | 06:39 PM
flyinZ's Avatar
yea, Jay's are like, 4.5lbs a piece..They're a pretty slick piece.
