The Z is on a major diet!
Taking the dash out is a pain, that's for sure. Good time to go after the passenger airbag if you haven't done that yet.
What chunk are you talking about?
So far I have the heater core, ac evaporator and some ducting out for 8 pounds savings. More to come. AC evaporator weighed right at 4 pounds. Heater less.
This is about an hour job and doesn't require the dash to be removed. Not sure about the rest but appears to be much easier with the dash out. I think that "L" piece will come out without the dash out. What did you cut out of the "L" piece? Is the "corner" the part that holds the box with wires right behind the glove box? (what ever that is)
And the part over the tunnel that had most of the flappers and openings in it.
The part that's remaining is what was the corner of the L, but now it's just a cube. Yep, it's behind the glove box, and has the resistor coils for the blower, the blower itself, and the heater core. And the cable and flapper for the warm/cold dial.
I keep meaning to weigh it too, but just haven't gotten around to it yet...
Thanks John D. I haven't worked on mine anymore but will get around to it.
I used some aluminum sheet attached with a couple screws and aluminum tape to cover the big opening and upper smaller. I painted the sheet black on the engine side. This is .008 thick aluminum sheet that only negates a couple ounces of my weight savings. Pretty happy with the weight reduction and looks. Can't tell any thing is gone from inside the car as I only removed what you can't see.
My plugs are sure going to be easy on the passenger side now.
