Drag Racing Tech
i need mini tub pics
Old 06-28-2006, 11:06 AM
jshiver's Avatar
Originally Posted by BLWN1
So you have to modify the rear suspension?
No...But, why would you mini-tub, if you were going to stay with stock stuff? The reason to mini-tub is to go with bigger tires, but if you don't use aftermarket suspension components, you are REALLY limited in your choices.
To answer you question tho...You don't have to modify any suspension pieces to mini-tub...just the body has to be modified.
Old 06-28-2006, 01:24 PM
BLWN1's Avatar
LS1Tech 20 Year Member
I didnt know if the wheels and tires would clear everything. Our True Street class allows tubs, and I believe stock suspension, that is why I asked....
Old 06-28-2006, 01:56 PM
jshiver's Avatar
I am building the same thing, but...when they say "stock suspension"...they mean...you must use "stock" mounting points...not stock parts....You will need to go with offset adjustable lower control arms,adjustable panhard bar, adjustable spring perches.
Old 07-06-2006, 08:35 PM
ThaLS1KidII's Avatar
Originally Posted by smokinHawk
anyone make their own instead of buying the kit? seems like you could make it with some sheetmetal and some snips.
can we get some pics of it being cut before the tubs are on, id like to put them in when i do my cage.
My roommate did his own. Here are some pics from the outside, I will get some pics of the inside tomorrow.
http://www.gmhightechrides.com/cgi-b...?m-1151642105/
Old 07-13-2006, 11:40 AM
BLWN1's Avatar
Didnt see any pics?
Old 07-13-2006, 05:29 PM
Lafngas98Z's Avatar
Here you go, they still arent done but you get the idea!! The tire is a 315 60 15 MT drag radial http://www.gmhightechrides.com/cgi-b...?m-1152827954/
Old 07-13-2006, 06:07 PM
jshiver's Avatar
Great pics...How much is rear narrowed and what width wheels with back space?
Old 07-13-2006, 06:22 PM
Lafngas98Z's Avatar
The rear is narrowed 3" per side. The wheel backspace is 5" on the wheels in the pics. I am about to order a 5 1/2" bs wheel. That should put me where I want to be!! Thanks for the compliments!!
Old 07-13-2006, 06:24 PM
BLWN1's Avatar
Not registered....
Old 07-13-2006, 06:29 PM
Lafngas98Z's Avatar
Not registered....
It just takes a second!
Old 07-13-2006, 09:41 PM
jshiver's Avatar
Very nice
Old 07-13-2006, 10:48 PM
  #32
Lafngas98Z's Avatar
Very nice
Thank you!
Quick Reply: i need mini tub pics
