Drag Racing Tech
Bolt in roll bar and the fuel pump access mod
Old Feb 17, 2006 | 04:51 AM
FASTFATBOY's Avatar
Default Bolt in roll bar and the fuel pump access mod
With the over the seat bars and that spot where the bars bolt to being cut out for tank access, how much weaker is it? Would it hold up in a rollover?
David
Old Feb 17, 2006 | 10:23 AM
Ls1LikeNoOther's Avatar
well ur bars should be right next to or behind the shock mount,and the access panel is in the middle...It shouldnt be any weaker than those floors are already..As long as theres like a 6" square plate on the bottom of the bar it should do ok..
Old Feb 21, 2006 | 03:14 AM
ace68's Avatar
are those panales legal for IHRA and NHRA, I thought there had to be an complete shelding from the gas tank to the interior.
Old Feb 21, 2006 | 03:17 AM
CAT3's Avatar
Restricted User
The tank is still outside the vehicle, and lots of ppl make an access panel to cover it, which is by far more removed than some of the fabricated "walls" for sale. Not sure it hold up any better or worse from the access door, but as pointed out, on the plastic tanks the hole is centered and to the rear. With the provided 6x6 plates you should be pretty good.
Old Feb 22, 2006 | 03:03 PM
1fastWS6's Avatar
Legality won't be an issue, and I don't think strength with be either. Here's what I did when I did my pump.
http://community.webshots.com/photo/...47068123iyRqwJ
