Drag Racing Tech
Drag Shock setup
Old Mar 11, 2006 | 02:29 PM
ApacheDrill's Avatar
Default Drag Shock setup
Okay i went and got a set of QA1's and springs for the front.. Should i go with the same thing on the rear or go with a less expensive shock for the rear like the Competion Engenering? Just seems to me that the fronts are what really matters and that there are less adjustments on the rear.. Let me know your thoughts on this.. If i had a unlimited budget, it wouldnt be a issue.. but if i can save a few hundered, it can be put to good use elsewhere..
Old Mar 11, 2006 | 09:12 PM
Nothing? No opinions on rear shocks or even if they matter? WOW..
Old Mar 11, 2006 | 11:04 PM
mvonada's Avatar
Why stop with QA1's on the front, put them on the rear! Real happy with mine front and rear.
Old Mar 12, 2006 | 09:23 AM
monsterls1's Avatar
I went with QA1's all the way around with 275lb springs in front and stock v6 springs in the rear.
Old Mar 12, 2006 | 03:16 PM
Racer8102's Avatar
I know how it is having a limited budget, but go ahead and at least buy the single adj for the rear, that's what I did, that way you won't be wondering down the road if that could be your weak spot. I am running Strange Dbl. adj, fronts, and single adj rears.
Old Mar 12, 2006 | 04:54 PM
SLPSS99's Avatar
Save and get the Rear QA1 12way coilovers, I just picked some up and they are sweet!! Then you have full adj. for ride height and how stiff you want the them in the rear.
Dan
Old Mar 12, 2006 | 06:32 PM
trigger1's Avatar
I went with a CE in the rear and qa1 and 275lb spring up front.
Old Mar 12, 2006 | 10:48 PM
Doofy's Avatar
I've got the same setup as trigger1 going on right now. I was wondering what your opinions are on the V6 rear springs? Contemplating on giving them a shot
Old Mar 13, 2006 | 08:53 AM
Carbed4thGen's Avatar
Dan
Wouldnt this be changing you from stock suspension to modified though? So for some classes you wouldnt cut it?
Old Mar 13, 2006 | 09:16 AM
SLPSS99's Avatar
Yeah I never thought of that as I just run in a pretty basic Bracket class with not to many rules i guess!!! My class I run cars that run 12.99 and faster and it is a money class, they can use delay boxes, trans brakes, almost anything goes, they are just tough on the saftey stuff like DS Loops, rollbars, etc. Hell if I am consistant I can usually make it quite a few rounds!!
Dan
Old Mar 16, 2006 | 09:06 AM
I run true street and cant go in that direction either.. Thanks for everyones thoughts.. Guess i will stick with whats up front and just pony up the other arm and leg..
Old Mar 16, 2006 | 01:05 PM
12secondv6's Avatar
Just an FYI, if you get V6 springs, make sure they are out of a 93-97 v6.
98+ v6's got the exact same lb rating as the v8's
Old Mar 18, 2006 | 01:14 AM
Elite_Hot_Rod's Avatar
I was running QA1 R Series 12 way adjustable shocks and Eibach Pro Kit springs on all 4 corners cutting consistant 1.32 60ft's. I run true street also, now I run AFCO coil overs in the front and AFCO double adjustable drag shocks and short drag springs with Wolfe Racecraft adjustable spring perches in the rear.
Old Mar 18, 2006 | 06:54 AM
What are your 60 ft times with the AFCO's?
Old Mar 18, 2006 | 12:22 PM
1.37 is average with the AFCO's the way we have them set up.
Old Mar 18, 2006 | 03:06 PM
skipperbisket's Avatar
Elite, those 1.37s are on an et street tire correct? like 9.4" of contact patch...
i'll be running the same class as Elite this year with a similar setup, only i'll be using QA1s in the rear with the adj. spring pearch and not sure what springs yet.
Old Mar 18, 2006 | 03:08 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm running QA1 R's in front, regulars in back. Stock 99 springs front and back, but the rears have a few coils cut to lower the car.
Best short time 1.35 spinning.
Old Mar 18, 2006 | 03:24 PM
Elite, if you ran 1.32's with the QA1's and 1.37 with the AFCO's, why did you change? Not trying to be funny cause they are pretty close.. was there another reason?
Old Mar 18, 2006 | 03:38 PM
fastlt1's Avatar
Which is more important front shocks and springs or rears?
Old Mar 18, 2006 | 05:05 PM
LS1Tech Co-Founder
Front drag shocks first.
