Drag Racing Tech
Hood pin locations
Old Mar 17, 2006 | 09:49 AM
Shon Herron's Avatar
Default Hood pin locations
Any pix of where you mounted the stud for the hood pins?
I thought about putting a set of pins on the stock 'snubber' location, it would be just about perfect but not sure if that will hold the front of the hood down at the top end of the track. Does it need to be more closer to the center?
And how did you do the rear of the hood, I saw one pic of an aluminum L bracket made that looks like it would work.
Are there any other pix? Or ideas?
Old Mar 17, 2006 | 08:35 PM
theblur98ss's Avatar
On my 98 SS there were 2 holes in the support going across on each side of the radiator. I just drilled them a bit bigger and put my pins there.
