Got the door bars out
No need to make any special tooling. I went to Sears and bought a set of metric sockets that allow you to use a wrench on the end. VERY slim so it's easy to get to the bolts. The damn glue makes it hard to turn though
.You'll need 10mm for the bolts towards the door hinge side and 15mm for the bolt on the door striker side. I was able to pull the bars through the grommets on the doors.
I know this thread is old but I was very helpful for me. I figured I would add a little more to it for future reference.
I can't wait to pick them up and get those bars out, thanks!
Did you cut the brackets out? They looked spot welded but I could be wrong.
Up to now I have not cut up the car and I'm going to try and keep it that way as long as I can.
BTW, FWIW I weighed my car in at 3060.
BTW nice weight
Do you have A/C, heat, cruise, etc..?
BTW nice weight
No, all has been removed. Stereo as well. I have not chopped the harness or removed the sealant but don't plan to either. I removed the passenger seat for another 36lbs (measured) since the last weigh in. I'm about to put in the order for the drag brakes in a day or so and buy a kirkey seat as well. Also stock carpet has been removed and replaced with Ozite.
K-member, A-arms and fiberglass hood are next. I'm hoping that should be enough to get me into the 28XX range without cutting up the car.
I ran a 12.27@109.7 on a 1.681 60' in 7300ft DA of air last weekend.
This weight reduction can be addicting
, we'll make quick work of it. The Best V8 Stories One Small Block at Time
which might be coming out this winter and make it more of a track car
I mean street car.
I mean street car.Car is now at 2920, no cutting. Changes have been kirkey seat and mild steel brackets, fiberglass hood and 6 years of dirt and grime
Still no K-member or drag brakes! Another 80-100lbs or so.
I took a short cut and just drilled out the jamb side of the door to get them out quick. I was gonna pull them out the front but I said screw it.
All the info posted was a BIG help, thanks a lot guys.
i know someone that used a plasma cutter, he wound up bubbling his paint.
