325-50-15 MT Drag Radial Pics!
You will find that anyone running the 325's with those Pro Stars has done a buttload of hammering or is running a really small spacer.
Originally Posted by xssive
I am talking with prostarts only. There was a thread not too long about with a white ta and stock length moser that didnt rub at all with 325's and no mods were done to fit them.
I have also seen pics here of another white ta that was slammed on 325's with little to no rubbing
Okay so I have a 2000 WS6 T/A and if I order a set of Bogarts 15-10 but with the 7.0 B/S they would stick out approx. 1/2 inch and fit without major mods to vehicle. i allready have the Strange brakes front and rear. Or does the Bogarts with the 7.5 B/S just made slightly different then the weld pro stars? Thanks for you feed back. Car look killer..
Wayne
Wayne
Let me make it clear that this is an LT1 car. I strongly beleive that it doesn't make a difference though. Also, I have set the suspension up on this car to hook on a drag radial with maximum bite. The rear axle has actually been moved forward a slight distance. Not too noticeable by looking at it but, makes a big difference in weight transfer when the rest of the car is set up right (pinion angle, instant center, vehicle ride height, weight distribution) . So since I did this, it was a must that I cut a major section of the inner wheel well on the front side of the rear tires.
Also, there are no rear wheel spacers on this car. Minor caliper grinding required.
Originally Posted by Luis Castellanos
last picture is another car?
no SFC's / Spohn Arm?..
Originally Posted by MRI-TEK
Well this particular vehicle was leveled ( most likely lowered a little in the rear as well as the front ) I\C was checked and P\A was set. So , lowering a vehicle with that size tire is definitely going to take some " massaging". I would think..
#32
The difference in these 2 cars is that if we would park these cars side by side, you would notice that with the same size tire set-up on each one, the camaro will be perfectly level with the ground. It does not have the "high rear" rake that the T/A does. For example, If I would put a set of stock camaro wheels/tires back on this car, it would be about an inch lower in the rear. Make sense?
Heres a tip....
If you set up your suspension on your car and lets say you put 3-4 degrees of pinion angle in it when all said and done and you do not compensate for the 3-4 degrees of rake that the actual vehicle and the rest of the driveline has in it, how much pinion angle do you actually have ? Anyone?
#34
LS1Tech Co-Founder
I'm running 28W on Bogarts, and they fit great. I have the car slammed right down on the tire. Since the Bogarts are like a 7.0 backspace, they are kicked out a bit more and that negates the need for a spacer. I'll try to mount my 325's on my spare rims and post some pics next week.
#37
Originally Posted by phoenix
can you post any pics of the mods you had to do?
#38
so how much hammering is required? i mean a lot or what. and that white ta didnt roll his fenders i dont think. if the car isnt lowered do you think rolling the lip is necasary?
