think i can hit 11's?
i just started over with a a 98 a4 formula. i ran the car BONE stock on drag radials and it ran 13.58@ 102 with a 2.0 60ft. 3605 race wieght. Im taking it apart in a week or so and here is whats going in....
-Magic stick cam (237/242 .603/.609 113lsa)
-fuddle 4000 stall with 2.4 str
-subframe connectors
-umi lca's and phr
-umi non adjustable Torque arm
-pacesetter long tubes with y pipe (no cats)
-!AIR
-!EGR
-fast 78mm tb
-slp lid with ported and descreened maf
-ngk tr55's
-26,000lb tranny cooler and b&m shift kit.
-pcmforless tune
The car will still have the 98 ls1 intake and has 3.23 gears. i think it will be around 3540 race weight or lil less.
i have 255-50 16 mt et streets dot radials
think i can get in the 11'???Any opions will be greatly appreciated!!
-umi lca's and phr
-!AIR
-!EGR
-fast 78mm tb
-ngk tr55's
-pcmforless tune
yes if the tune is decent you should... im prolly setting at about 11.70 and my shitty tune ect only made 341rwhp... but i was prolly 200lbs lighter then you... but if u make a lil more power.....
I think you will need a little more work, even with a good tune. I would put her on a diet and lighten up the front, get some good shocks so when you launch you can get weight transfered to the rear and come out of the hole with a good 60' time.
