Drag Racing Tech
Ac Box?
Old Apr 14, 2006 | 06:36 PM
KAOS's Avatar
Default Ac Box?
the ac box. does it just unbolt and come out? what is everybody using to cover it up, or is there anything to cover up. figured i would take it off since i dont have any ac
Old Apr 14, 2006 | 06:47 PM
WILWAXU's Avatar
Lets try this in Drag Racing tech.
Old Apr 14, 2006 | 06:52 PM
ROCNDAV's Avatar
When I took the AC box out of my IROC, I took the box that held the (what the hell is it called, not the condensor..its the other finned device by the firewall) "thing" and cut it with a dremel, leaving only the flanges which bolt to the firewall and just enough "border". I then fiber glassed the opening. Came out pretty bitchen, after it was painted. At the time, you could buy an 1LE box (no AC ), but they wanted something like $300 for what I did for $10 or $20 (back in 93)
Old Apr 14, 2006 | 11:08 PM
KAOS's Avatar
so there will be a big hole there right? thanks for movin it didnt know where is should go sorry
Old Apr 15, 2006 | 08:18 AM
sbcgenII's Avatar
I took a clear piece of plastic traced around the hole then used that as a templete to cut a piece of thin steel, then put weather strip around the outside of it to keep any fumes from coming in. Or you can buy one from -->billingsly for $59
Old Apr 15, 2006 | 08:35 AM
theblur98ss's Avatar
You have to pull the dash to take it out. I just got some aluminum and cut a patch. I think I riveted it in place. Painted it black and you can't even tell anything used to be there. I've heard it needs to be a certain thickness to pass a chassis certification though.
Old Apr 15, 2006 | 11:46 AM
KAOS's Avatar
so i cant take it out from under the hood. that sort of sucks. you have to pull the whole dash to get to it?
Old Apr 15, 2006 | 01:56 PM
KAOS's Avatar
does this eliminate the heater core? dont want to do that. still want the heater, just no air
Old Apr 15, 2006 | 06:41 PM
Taubr Unit's Avatar
yea, i want to do the same. But i got a lt1, my buddy took it out of his ls1 and it looks badasss. I did the same with my old iroc, but when i pulled out the a/c box my heat didnt blow or anything. I took out all my a/c out of my lt1 and wanna pull the big **** box out too but i dont wanna loose my heat eaither. And any tips on pulling the dash out too. Any hidden bolts i should be aware of.
Old Apr 16, 2006 | 09:20 AM
Yes you will lose your heater core and blower motor. There is a bolt directly behind the intake the needs to be taken out. There are some bolts that are kinda hidden but you'll find them. I opted to take out the stock setup and put in a mojave heater. Alot lighter and tons more room.
Old Apr 16, 2006 | 09:10 PM
KAOS's Avatar
ill have to revisit it some other day. got other stuff to pay for now. thanks for the help
