Tire Grip
I´m going to buy a set of M/T drag Radials 255/50/16 will that hold or should i go bigger
And I can buy a set of BFgoodrich T/A drag radials 255/50/16,are they better than M/T?
I have a 400rwhp M6 with 4.10 9"
With an M6, I don't think that'll hold, to be honest with you. I know some A4 guys who have hooked on those, but they had suspensions set up to do it. I could probably do it, but I'm Stock Internal, Automatic, and I'm setup for drag.
I'd go with something with a larger sidewall and more width. You might be able to hook on a ET Street Bias Ply 26x10.50x16.
Do you have a little more info on what you have done to your suspension?
Originally Posted by Ari G
I have Adj LCA´s,Pahard-bar,TQ arm and Relocation of the LCA´s
FWIW, I've got a friend with a 99 SS, with 350-ish HP, M6 with a Ram Powergrip HD, on 315/35/17 Nitto DR's, with more suspension mods than you ( QA1's, lots of weight reduction ), and he didn't always hook on those, even with a good burnout.
Try the wrinklewall, I think you'll be surprised.
