!Radio what to put in place?
Dan
Here's where I got it, http://www.partsexpress.com/pe/showd...number=265-940 . They make different thickness', go with the thickest stuff if your putting any gauges or switches in the panel. I just ran alittle super glue around the inside edge to hold mine in.
I took everything out except the alarm sensor too, I just cut the wires by the kick panel and covered the ends of the orange (power) wires with some heat shrink. Then just cut the rest of them so they arent even, taped them up and made sure they werent around any metal. As far as fuses just keep pulling them until something doesnt work that you want to work
I used the power switch (plus a simple 2 transistor latching circuit) on the radio to arm my BS3 logger and the radio 'theft' LED lights when its armed so I know if its recording a pass.
I also left the heater control, the fan switch turns my cooling fan on and off and the 'mode' switch turns the EWP on and off when the car isnt running. Why waste perfectly good factory switches
Seems like a lot of work but I only have one aftermarket toggle switch in the whole car and I think it looks pretty clean like that but some guys like the race car look... Mike
http://i85.photobucket.com/albums/k5...1/DCP_1465.jpg
Less than $10.00 from the dealer.
