Question about tire diameter?
My question is how much would a 28" tire help in this situation? How much faster can you go in 4th gear with a 28" tire compared to 25-26" at the end of the traps?
Thanks
Isnt there a way to calculate the speed possible with tire size and gearing?
I did the numbers there and it showed 13 mph more at 6700RPM running 28" tires instead of 25.6"
Im not really sure about the calculator though because it showed the 25.6 tire good for 137mph while i was close to my limiter which is around 7K RPM (I remember getting shift light on before i passed the traps and my shift light is set at 6300RPM) and only trapped 127mph.
I used these gearings numbers for the T-56, 2.66, 1.78, 1.3, 1.00, 0.74, 0.50
