Drag Racing Tech
What kind of adjustments too make.....
Old 04-30-2006, 07:24 AM
SlickVert's Avatar
Devon
Madman is correct, go get it scaled.
If you can’t get to it soon, try doing this;
Unhook driver side link
Sit car on level ground in race trim
Sit in the car with all your race gear
Have someone adjust the right rear end link so it will line up with hole with no preload.
This is only a band-aid until you get it scaled
Bob
Old 04-30-2006, 08:36 AM
Loudmouth LS1's Avatar
Originally Posted by SlickVert
Devon
Bob
Have you had urs scaled? Just wonderin if you did who did it so I know who to go too.
Old 04-30-2006, 09:11 AM
ApacheDrill's Avatar
Your setup is hooking hard Devon.. if my 60 ft times where what yours are, and i was lifting that hard.. i wouldnt be complaining.. im sure thats not what u want to hear, was meant as a compliment.. its bad ***
Old 04-30-2006, 09:58 AM
next's Avatar
Devon,
I'll send you some info.
Old 04-30-2006, 10:14 AM
Thanks dude, i'm not complaining, I just wanna get her to come out even and also gotta get her not to treck left and be consistant in her 60's, cuz sometimes she'll dead hook and go bottom 1.3's and others it's a little spin and bottom 1.4's, I want bottom 1.3's to 1.2's all the time!
Old 04-30-2006, 10:15 AM
Originally Posted by next
Devon,
Thanks Eric!
Old 04-30-2006, 10:35 AM
redline2k's Avatar
Well i'm sure it's probably the posi that's causin her to treck left and i'm gonna get a spool asap, but could it cause her to twist? It's weird too, cuz sometimes she'll twist (usually only if she spins) and other times the fronts will come up even, but then in that one pic you can see that even though the front is even, the rear is still twisted, so i'm not sure what's up. Here's another still shot and video, she looks straight from the front, but no back shot too see if she's straight back there.
http://www.mattz28.com/Devon1.wmv
I have never seen my front twist. If it spins mine doesn't lift the tires. My car has a 12 bolt with a true trac in it.
Old 04-30-2006, 02:16 PM
SlickVert's Avatar
Yes, I scaled it myself.
I borrowed some scales from the airport.
Bob
Old 04-30-2006, 02:32 PM
Bob
Oh ****, you think you could borrow them again one day and help me out?
Old 04-30-2006, 03:33 PM
Dude, I just noticed something else this morning while I was under there adjusting the swaybar. I just sent my rear qa1's out to be rebuilt and only raced with them last weekend and a little street driving and there's a bunch of oil all over the right rear shock, not sure if it's oil from the shock though. I'm gonna be pissed if the shock is messed up, I just got them back. How can I tell if the shock is screwed and if I have to send it back to them?
Old 04-30-2006, 07:51 PM
My sway bar is setup with no preload. The perosn who set my car up thinks your posi could be the cause if it is weaker to one side, or one of your control arms could be slightly longer than the other, but if you want to preload the bar make the driverside shorter. I hope that helps.
Here is a couple of videos of mine launching:
http://redlineperformance.biz/fundaydec05.wmv
http://www.redlineperformance.biz/wheelie.wmv
By the way, awesome videos!!!! Just got around to dl'ing them and they're killer!
