Any step by step directions to !Cruise control?
Just would like to know if there are any write up's on this or not? I did a search and did not find anything? I really would like to get this Cruise out asap!!
Dan
Dan
I looked for a write up for a while and couldn't find anything. Finally I just started ripping **** out. Worked great for me, just make sure to get the throttle cable made for cars without tcs. That way you just rip out the whole unit and everything the cables connect to, then just put on the new throttle cable and it goes from the throttle body straight to the pedal. This is assuming you don't care to keep tcs either. Good luck.
It's pretty simple. Just get a throttle cable for a non tcs car and rip everything out with a cable on it and put in the new cable. Follow the cables to the cruise module. It really cleans up the engine bay as well.
