Drag Racing Tech
Two Step vs. T-Brake
Old May 5, 2006 | 05:08 PM
68maro's Avatar
7 Second Club / STF Veteran
well if you wire the 2 step to the break pedal it will be interesting watching you do your burnout in the waterbox when the rev limiter starts banging at 4500
Old May 5, 2006 | 05:33 PM
SUX2BU's Avatar
Thats why you have a master on/off switch and the brake/transbrake switch. With the master switch off the two step won't work.
Old May 5, 2006 | 06:19 PM
68maro's Avatar
then why not just put it that way on the transbrake button instead of the brake pedal.
Old May 6, 2006 | 04:13 AM
CAT3's Avatar
Restricted User
I will be wiring mine to the transbrake. I've had it for a year now, never installed it. So time to get off my *** and geter done.
Old May 6, 2006 | 09:12 AM
PewterZ28's Avatar
Line lock should also get me around this problem, right?
