Help me with my bad combo
Truth be told, I'm not very happy with the car. I'm about ready to redo most of it, since the combination seems that it is pretty bad. I didn't really get the chance to pick and choose the parts (referring to cam, gears, converter, headers, etc), they just sort of got tossed in there, so it's not like I chose these parts to go hand-in-hand
The main problem is the car feels like it's driving through the converter a lot at lower speeds. Once it picks up after about 3k it feels fine, but once it hits 2nd gear the car feels like it just hits a wall. Example, I ran a modded STi the other night. He launched at like 5k and hooked good, I only hooked decent enough not to get blown away off the line (cold road and my suspension is not adjusted right working against me there). I was able to hold up and end up about a car and a half on the guy through first, but as soon as I hit second I only got another half a car or so on him, and then at the end of the race that's where we finished, with me about 2 cars on him. The guy only has some basic mods on this STi, nothing major. I know that I won't make the same power to the wheels with the auto vs the 6 speed, but it felt this way with the 6 speed also, sort of dying off in 2nd
Currently it has a hotcam (219/228 112 LSA), factory 3.42 geared 10 bolt, a 4000 stall (a rather loose converter, unknown STR), and a 2.52 - 1.52 - 1.00 geared th350. Rear tires are 275/60 15 on 15x10 wheels. Headers are coated MAC mids with 2.5" duals. Lastly, car has most bolt ons (missing 2 or 3) and all free mods, and some tuning by MadZ28
I'm ready and willing to change out most anything on the car to get the combo right, and I'd obviously like to make more power. The bigger parts I had in mind was a custom grind cam, bigger gears (3.90s are my preferance, and the highest I'd like to go), and a new converter to match it all. I'm also going to switch to long tubes, since it feels like I'm leaving a bit on the table with these mids
Back when the car was a 6 speed, all I was able to get out of it were some 13.1's @ 111-112, at a very poorly prepped track. I'm confident I would have had closer to mid 12s had the track been actually prepped. All they did was brush off the dust after the track had sat through a Kansas winter!. This was on balding street tires also, no drag radials or slicks. I'm not a very great 6 speed driver (when it comes to launching) which is why I switched to the th350
So, any suggestions or input? I don't mind "streetability" too much, obviously since I'm currently running a 3 speed on the street. I might look into a gear vendors or a different tranny, so any suggestions there would be nice also. My goal for the car for now is to crack some 11s N/A, and spray it to the 10s after that. I'm not too interested in any sort of auto-X or much for handling in this car either
TIA
Tires are 275/60 15 which should be 28x11.5. Spray yes, but not worried about that since I want it to be running right N/A before I spray her
When I was running the 13.1s I was getting horrible 60' (zero track prep killed it for everyone, the balding street tires even worse for me) times, I think the best was like a 2.4
Not sure on exact weight of the car, it's roughly stock minus about 160-175 pounds
*edit* The 13.1 @ 111-112 was with the 6 speed, since then there were a few suspension bolt ons, a ported tb, the wheels/tires, and tuning. And the th350 now obviously
Well I emailed Fuddle, a new converter will be the first thing I change out. I'm going to try a converter like yours, ~3800 with a ~2.2 str, since the only thing I know about my converter is that it's a 4k. It's very loose, and the car drives through the converter very badly. Maybe it just needs that and higher gears to help with how sluggish it feels
Would a 4.10 gear be a little extreme since I'm running a th350? I guess gas mileage doesn't really bother me that much, I'm more worried of running out of gear too quick, especially while spraying. And does anyone know if the TRAK likes 3.90 or 4.10 gears?
and good choice on the fuddle 3800. it will love the spray.
I'm talking with the Fuddle guy now, should be purchasing the converter in a couple weeks, after I do the gears. Thanks for the advice on it!
