Power steering delete drivablity
I do have skinnys, and im sure that they will help the problem, but im just looking for some tricks to help out with the larger tires.
I've known guys try 16" wheels (245 or 255 tires). They ended up taking the racks off. PITA.
Skinnies drive with no problem at all. Just don't try to corner or panic stop with them.
Thats off the top of my head but I think thats right.
FYI I have rebuilt the front suspension in my 94 and keeping the ball joints and tie rod ends lubed up helps with the manual steering.
If I remember correctly the stock ones don,t have grease fittings so you would have to install new ball joints.........just something to think about for the future if your going to keep the manual steering. I have gotten used to it so I am keeping it.
By the way IBWSjerry, it doesn,t look like your belt is going to line up.....you will probabley throw the belt if you run it like that.
Most of the PITA of my install was spacing it correctly so the belt was lined up right.
