Drag Racing Tech
COLD starting pressure for ET Streets
Old May 10, 2006 | 07:38 AM
YO-EL's Avatar
Default COLD starting pressure for ET Streets
New user here..
I've been using 14 psi hot...
Where should I do my 1st run at while they are cold??
Old May 10, 2006 | 07:59 AM
LETZ RUN's Avatar
what size? id say 10lbs cold.
Old May 10, 2006 | 08:56 AM
smoknta's Avatar
I had been running my around 10-12 last year and getting decent results. But last weekend I decided to try something different and go up. I got the best results around 18 Hot. Ended up cutting a 1.61 60ft. I'm running on 26x10.5x15.
Old May 10, 2006 | 09:36 AM
Bitemark46's Avatar
That's what I start out with. I try to stay around 12lbs hot. Typically going from cold to hot is about 2 psi from what I've seen. -Mark
Old May 10, 2006 | 05:38 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Best way is to do a dry launch on a clean piece of asphalt or concrete and see how the pattern looks. Dark on the outer edges but light in center means too low a pressure, where-as more color in center versus the outside is too much. I wouldn't go much below 13-14 psi as the tire starts to cup, and you lose contact patch.
I ran my 28 x 12.5 x 15 at 14-14.5 psi cold (about 14.5-15.5 psi hot).
Derek
Old May 11, 2006 | 07:59 AM
YO-EL's Avatar
26x11.5x16
