Drag Racing Tech
Dyno Sheet, when to shift?
Old May 13, 2006 | 04:00 PM
bastien's Avatar
Default Dyno Sheet, when to shift?
Could you guys tell me when I should shift according to my dyno sheet?
Thanks a lot
around 5.2k-5.5k, am I correct? I have a shift light so I don't have to worry about the tach lag.
Old May 13, 2006 | 04:40 PM
black_z's Avatar
You want to shift higher than that. I would go 5900-6000.
Old May 13, 2006 | 04:59 PM
iOWNaWRX's Avatar
Why would he shift at 6 if full torque was at 4.5 and tapered off badly after that
Old May 13, 2006 | 05:11 PM
silkey's Avatar
as i understand it,when you shift into the next gear you want the rpm where the torque and horsepower cross.
Old May 13, 2006 | 05:15 PM
silkey's Avatar
in other words,after you shift into the next gear you want the crossing to be the start(lowest drop) and go on from there.
Old May 13, 2006 | 06:15 PM
BlueSix's Avatar
Horsepower and torque always cross at 5252 rpm. That point has nothing to do with determining your shift point.
Old May 13, 2006 | 06:16 PM
BlueSix's Avatar
Because you want to shift a few hundred RPM after your horsepower peak. He peaks at 5500. He needs to shift at 6000.
Old May 13, 2006 | 06:17 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs up
Thank you....
Old May 13, 2006 | 07:03 PM
bastien's Avatar
thanks for the replies
Old May 13, 2006 | 09:42 PM
CamTom12's Avatar
Think of it in terms of gear reduction and torque multiplication.
Even though you'd be making less engine torque at the top of 2nd at 6000, you'll still be making more wheel torque than you would in 3rd at any point in the powerband. The bottom-line is to shift at your red-line on a graph that looks like that.
Old May 13, 2006 | 09:53 PM
bastien's Avatar
thanks a lot
Old May 14, 2006 | 07:24 PM
mike c.'s Avatar
the car is a m6? if so you are supposed to shift about 200 rpm's past your peak hp. this keeps you in the sweet spot of your power band. going 500rpm's past it will not help your times. get a shift light,summit has one for $50.00. it has a dial on the back so you can set any rpm you want,no pills for this light. this will help you find where the car need to be shifted. i have one mounted on my steering colum in front of my factory tach,it's small and not really in the way. good luck to ya.
Old May 14, 2006 | 08:20 PM
Ryan02SS's Avatar
Anywhere from 5800-6000rpms if it was mine. I would take it to the track and see if it makes much difference assuming your 60's and shifting times are similar.
Old May 15, 2006 | 06:39 AM
silkey's Avatar
let me see if i can clarify my statements,i believe after you shift you would like the rpms to drop no lower than the cross over point.as far as the max rpm shift,that is yet to be determined,gear ratio,trans ratio and what the engine can turn safely.but what you have is what youre stuck with but i believe if you try to get near that goal you would see youre best times.if you dont want to go through all that trouble then just get the next gear shift to start in about the middle of the peak torque band.
Old May 15, 2006 | 07:36 AM
SlickVert's Avatar
For the best ET 6,200 to 6,300rpm
Bob
Old May 15, 2006 | 10:10 AM
BlueSix's Avatar
Old May 15, 2006 | 10:33 AM
bastien's Avatar
thanks, I already mentioned I had a shift light
Old May 15, 2006 | 10:42 AM
silkey's Avatar
hey blue six,all i can say is it works for me.by the way,what times do you run?
Old May 15, 2006 | 11:01 AM
BlueSix's Avatar
mid 13's in a stock GTO. Shifting at 6000.
You're telling people that you want the rpm's to fall to the cross-over point after their shift. That's not correct. The hp/tq cross-over has nothing to do with where you shift or where your rpm's fall after a shift. hp and tq will always cross at the same RPM, on every engine combo.
Old May 15, 2006 | 11:18 AM
bastien's Avatar
I guess i'll keep shifting at 6000 rpms. Thanks guys
