Drag Racing Tech
Stupid question...why narrow the rearend?
Old 05-17-2006, 10:32 PM
  #41
LC
LC's Avatar
I still don't order my 6" narrowed 12 bolt, but Steve is making my 5" BS Bogarts
Old 05-17-2006, 10:38 PM
  #42
mike#9's Avatar
Originally Posted by gator's 99TA
wow lots of questions that can be answered with the search feature.
1) narrowing a rear affects the size of the tire you can run. tuck the wheel in too much and you will run into clearance issues. then you mini tub
2) you can order a rear narrowed as much as you want. cost is the same. weight reduction and stronger axles as above said.
I did search...and did not get my questions answered.
Thanks for the help though!
Old 05-17-2006, 10:42 PM
  #43
SScam68's Avatar
Really?
Damn!
Hey, my differential is suppose to ship this friday. I guess we'll see
Old 05-17-2006, 10:44 PM
  #44
LC
LC's Avatar
yeah!, should be around the same as Tom's setup... I hope I can run a 29" tire without having to minitub...
did you took pictures of the D10s on the car yet ?
Old 05-19-2006, 07:47 AM
  #45
TheOutlaw's Avatar
Originally Posted by DopeFedZ
I'm gonna try 3.5"-4" narrowing and run a 4"b.s. to see where I end up at.
3.75 per side is the most you can go on stock suspension car. The 4" back spacing looks so dam good. I just set one of my customers car up that way
Old 05-19-2006, 09:28 AM
  #46
gator's 99TA's Avatar
tell this to big rick or wormboy on here.
Old 05-19-2006, 09:32 AM
  #47
Carbed4thGen's Avatar
I thought wormboy and big rick both had to relocate their shockmount or control arm mount though to go more
Old 05-19-2006, 09:37 AM
  #48
I stand corrected. After reading some posts wormboy's rearend just has the control arm mount NARROWED not moved so its still stock location
Quick Reply: Stupid question...why narrow the rearend?
