When is it enough?
with a full interior.
That's a feat to do with a stick car.. or are you going the th400 route like the rest of us........?
The less time you spend on the track, the more expensive it gets
My Nova "only" runs mid 11s N/A and she'd run faster I'm sure but I save my pennies for stuff that make her hook consistently and a good bracket car, as opposed to stuff to make her faster. Started at 17 seconds with the stock 307 engine back in 1997, and I'm aiming for hopeful high 10s N/A next year with a little more cam and headwork. I've been running around the mid 11s for 3 years now, and wanting to step up a little, but not lose streetability. Plus I like factory appearing, so the 3500 lb raceweight (with me on board) hurts and I could easily drop 2 tenths shaving weight, so full interior, all steel body and street-easy are important to me.
The Formula follows the same philosophy: I could do a lot more, but already have 1 car that's my money pit. She's got 112,000 miles and anything I change to add power now will cost me in the "fix-this-and-that" catagory. So she will be left a daily driver with minimal change (only possible upgrades will be when the motor needs rebuilding, and then small stuff, but nothing radical).
So, is it ever enough? I don't think so, but how bad it gets carried away is up to you.
Derek
with this motor,
11's on motor, 10's on spray
swap to a low comp turbo setup, and 10's on low boost, and high 9's on high boost.
Both are attainable, and i do intend on swapping to a TH-400
), 6-speed.it won't be easy, but that's the goal.
it is a sickness, started out with the car just wanting an easy 12 sec DD, then low 12's, then 11's. i don't think i'll push it much more than it is now, as i think it is already on the verge of being really reliable.
it's not so much the engine that breaks, its all the other parts that try to hold the car together
Besides, it's all ready costing me 15K to run low 10's. I don't even want to think at what kind of a pricetag 9's & 8's has attatched to it
Oh, and hang on!Kinda hard to screw that up.
but more then once after my burnout i left it in 2nd gear, other times if your arm isnt braced, when you launch, you pull 2nd by accident, b-man was famous for leaving it in 2nd
its not hard, but it can be alot (maybe not on motor tho
thats what i live by
In over 3 years i have replaced everything on my car, minus the shell, k memeber, A arms and brakes..(thats my winter MOD this year)
The funny thing is when all 3 of them are replaced i am going back to where i started..
The motor.. I am going to start the build up on another short block.. The way i look at it, if it wasnt for the car, id be collecting star wars figures or something dumb and wouldnt have nothing to show for it.. My car is paid for and its all been done by me, thats priceless..
Oh, and some nitrous will probably find it's way on the car too... and I'll be gettign a nhra lic. at that point.
Hopefully, when it's done, it will be a show quailty car that can run a 10.50 index on motor, and on the bottle click off mid 9 second passes.
One step at a time though... one step at a time. This year, the car will be dropping nearly 2 seconds off what it ran last year, so that alone, I'd say was a good step foreward.
