Drag Racing Tech
Lexan Windshield Install?
Old May 18, 2006 | 03:42 PM
12secSS's Avatar
Default Lexan Windshield Install?
Anyone have any pointers to install a lexan windshield? I just got a Pro Glass windshield and it is oversized to trim as needed. I found out that you can install it like a normal windshiel or use sheet metal screws with weather stripping (for hieght adjustment). I plan on doing the countersunk screw method, but how do I go about trimming the lexan? What is used, just a cutoff wheel? Also how far apart do the screws go around the perimeter? Better yet, is there an article online somewhere? Thanks for any help.
Old May 18, 2006 | 04:34 PM
MADMAN's Avatar
LS1Tech Sponsor
Use a jigsaw with a 18 tpi blade. Trim till you are 3/16 from fitting. Then sand with a grinder with 80 grit till it fits. Final sanding to clean and straighten the edges use 200 grit sand paper on a 1" X 2" wood block.
As for screws I use 8 x 32 countersunk SS screws. I drill and tap all the holes.
If you will call me I can FAX you the instructions for proper spacing.
877-516-7223
__________________
www.madmanandcoracing.com
225-343-9029
Old May 18, 2006 | 04:49 PM
Mike TexaSS's Avatar
8 Sec Tuner
Madman is gay.
Old May 18, 2006 | 06:43 PM
MADMAN's Avatar
LS1Tech Sponsor
I just added $1000.00 to the IMPY bill!!!!!!!!!!!!!!!!!!!!!!!
__________________
225-343-9029
Old May 18, 2006 | 07:33 PM
1QuickT-A's Avatar
Originally Posted by Mike TexaSS
Madman is gay.
hahahahaha now that **** was random!
