Santa Claus came early
Weld finally decided to build some wheels. Here is a pic of what will be going on the rear. 15x10 4" b.s. Should have them on in the next week or two after the rearend gets narrowed.
In the meantime the centers will be getting powdercoated black.
Restricted User
Carlos, you narrowing 2.5" per side or 3"? Should tuck in nicely. I wanted to get a set of those, but where so backordered I went with Bogarts Welded Floyds instead. Look good though.
Restricted User
Originally Posted by DopeFedZ
Not really sure how much I'm going to have it narrowed yet. Pyle Bros in Baytown will be doing it for me though.
I said 2.5-3" based off having only a 4" BS, if not then it would probably not be enough BS and cause rubbing issues.
Originally Posted by skipperbisket
you had the same wheel on the rear before right, just with a 7.5" bs? what you going to do with that set?
