Battery Relocation - Alternator Kill
Just a quick question. I got the battery relocation done and everything works. I basically installed a junction box where the original battery was that joins:
(a) Starter positive
(b) Alt postive
(c) Alt negative
(d) power cable to back (kill switch)
The kill switch works great when the car is off, but since the ALTs are always hot (ground + hot) if the car is running the kill switch does not work.
I think I can just remove the alt negative cable from the junction box and ground it to the chassis to enable the kill switch to kill a running engine. Anyone ever do this? Will this work?
Thanks
One red is going to the starter
One red goes to the fuse box
the black goes to the alternator
the blue one goes back to the kill switch.
Here is a schematic for those electrically inclined.
and how i have mine wired:
Basically i want to avoid bringing another cable back to the back of the car. Is there any way to use the ALT cable (pointed at above) and ground it somewhere on the chassis and accomplish the same thing?
When the switch is closed, it's charging your battery.
You need a switch that will disconnect the hotwire from the battery, and break the connection from the alternator at the same time.
Or just connect the alternator between the battery and the switch. Then when you flip the switch, the engine can't see power from either one of them.
(b) Alt postive
(c) Alt negative
Thanks
