Slicks+full thorottle transbrake launch=close call with the wall-need suspension help
the wolfe swaybar is fine on the street as long as you don't try to "carve" corners when it's hooked up. also, you can unhook the swaybar on the street.(and when it's unhooked it isn't that bad really)
A Moser what?
Could be a posi going out, but I'd reccomend a Spohn rear drag bar, I think they are $350 or so. I've gone 1.35 with mine spinning a little, but leaving straight. The car is even in back and goes forward. I think my locker is dying so that might be the reason I have been seeing a little spin.
Thanks for the responses guys, I'm going to get a swaybar. I'm going to see a chassis guy on mon-tues and I'm going to ask him about the corner scales. This guy was watching my run when I got outta shape so he knows what the car is doing so I'll see what he says.
LS1Tech Co-Founder
Mark... posi/spool/locker? ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
The Spohn drag bar is a bolt-in, and has some give in it. The Wolfe and the Billingsley are fully welded. It's like driving a car with ladder bars around.
I know WS6TransAm01 has a sway bar which is a direct replacement.
But that photo above is an Anti-roll bar.
Actually, Tektrans, my car is going to the right, right at the launch myself.
I was/am looking into an Anti-Roll bar myself.
I heard they are hell on the street though?
Originally Posted by Anonymous
Those are really Anti-roll bars and not sway-bars correct?
On the street, just disconnect the passenger side endlink and you will be fine. Otherwise my Wolfe bar is pretty noisy.
You wanna know what parts specifically in the rear. Truth is I have no idea. I got this rear probably around, ****, 6+ years ago. Me and a few guys from Cartek got them around the same time. All I ever knew about it was it was a Moser 12 bolt w/ 33 spline axles if I remember correctly and I ordered mine with 4:10 gears.
Thing has whined like an old lady since day one. I've had the gears changed from 4:10's to 3:42's and back to 4:10's. Gears always looked good when they came out, I even re installed the old 4:10's when I got rid of the nitrous.
The car isn't exactly comfortable with the racing seats and doesn't handle that well with no sway bar and skinnies so if I went with the fully welded bar it wouldn't be that bad since I only really drive the car to the track and back and to the shop etc. But I'm not really sure I'm making enough power to really need the welded bar anyway, maybe the Spohn is all I really need.
But if the Spohn doesn't totally fix my problem, that would suck.
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
What about the BMR Drag Bar?
![](http://www.bmrfabrication.com/Xtreme/dragbar.jpg)
I have the Suspention Teqhniques 25mm Solid rear sway bar, the car leaves strait as. I'm sure, Anonymous can atest too. But once agian, I only make 507.9 RWHP
LOL
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
LS1Tech Co-Founder
The BMR drag bar pictured is like the Spohn drag bar. The Wolfe bar is welded on all four points, and the BMR and the Spohn ones have 2 rigid parts and two parts that use poly bushings.
#32
John, Does that BMR or Spohn set up work well?
I have mostly BMR parts on my car and would like to stick with BMR if it works?
How are these type on the street? That is probably more of a concern to me than Tektrans?
Maybe, Tektrans and I can get them together?
Thanks
PS. WS6TransAm01 does leave straight, only diff is he has a 6-speed we have Autos.
#36
Originally Posted by n2o
How about the rear alignment? Adj panhard? If the rear is off center that could be causing the issue. Is the car lowered in the rear?
#37
Originally Posted by GIZMO
Unless you are planning to make a major HP change a bolt in sway bar would be good enough (The bigger the better). With the age of your rear I would take a look at the posi. How much pressure did you have in the rear tires?
Daren
Daren
#38
Thanks
Thanks
PSJ- 1.35 is Awesome, I hope I can get close to that when I get this worked out.
