Santhuff spindle mount
As for that aje setup, the strut setup looks good, but I question teh strenth of that k member, that thing looks just a little too fragile. Plus, with struts on teh car like that, a strut tower brace might be needed to stop the front from really flopping around, at least if that k member is gonna be used.
you want the best of both worlds and its just not gonna happen... people who are interested in having strut front ends, normally would'nt care about how much abuse the setup will be able to take under normal driving conditions
and that aje setup drops the front end 2 inches, which is deffinetly not helpfull on these cars for street driving.. that was another reason I did not to get it.... jay
I was tempted to go with this set up... didnt feel like spending the 2000.00 bucks and once this is in the car it wont fit into stock suspension classes..if by chance someone takes a look under the front of the car..
jay
AJE's setup should be legal to run ORSCA (EZStreet), PRO (X-street), and the local races. I've got other things besides a front coil-over setup that will DQ me from most race series (twin 67mm turbos = not legal in most classes).
jay
I only plan to keep the car on the street for 2 more summers then it's off for track only use, at that point I won't have to worry about it... it's just a matter of what I can do between then and now that I can live with. A 2 inch drop on the front, I don't think I can live with.
There is nothing wrong with using the stock knuckle and shock setup with travel limiters on cars that see the street. If you want a spindle mounted wheel, buy a Strange front brake kit with the spindle. It bolts in place of the factory wheel hub and gets you close enough. The only issue is that you don't want to drive a spindle mounted tire on the street for much more than a cruise night.
From the pics it looks like a bolt in setup but just trying to confirm.
I believe its a bolt on...
I'm trying to knock as much weight as possible and if that means eliminating the upper A-arm so be it. I just don't know if dropping 2" in the front would cause any problems in terms of chassis dynamics during launch. I'm hoping some of you more experienced guys can chime in. Shooting for high 9 second car.
Sorry to get off topic.
SCHWEET! i win for once. go thirdgen!
I'm sure you could save upto 45-50 lbs with something like that.
The short travel of the struts would tear up either the mounts or the strut itself. That's why the only thing you see it on is track cars and not Wild Street/True Street cars. AJE's is a spindle-mount setup.
Rick
Santhuff makes set for $945 but also requires custom A-arms to be made to fit their spindle/steering knuckles
AJE makes a set of stock replacement spindle/steering knuckles for $699 that will fit stock A-arms, but will need a 3rd Gen style brake kit, like Aerospace or Wilwood.
He custom makes them and can go ½ to 2” drop (Minimum is ½ drop).
