new to track scene help!
what can i expect out of my 342 geared rear end with slicks?
any guess on time with medium skill street race driver?
any tips for first time at track?
i know 60 ft is everything to getting a good time so what launch rpm would you guys suggest as a starting point.
thanks for any help
thanks for any help
Full slicks?? On a 6 speed car with stock rearend and no upgraded half shafts is a recipe for disaster IMHO. Opinions may vary.
The new M/T DR's are just about as sticky as slicks if you heat them up. Maybe you should just do short or no burnouts??
Maybe if you slip the clutch just right on your launch, you can keep from shocking the weak parts enough to break them. You really should invest in some upgraded half shafts before you go to a sticky track with sticky tires. Stick to "roll on racing" from 50 mph until you get the stronger parts would be my suggestion. Good luck.
