Drag Racing Tech
Removing AC -- throw a code?
Old Jul 9, 2006 | 03:12 PM
NOTFAST's Avatar
Default Removing AC -- throw a code?
If you remove your AC will it throw a SES light?
Old Jul 9, 2006 | 03:48 PM
JNorris's Avatar
Moderator
No SES light but it will set an AC pressure high/low code.
John
Old Jul 9, 2006 | 09:59 PM
Demonicbird00's Avatar
i took mine out 2 weeks ago, and i didnt throw any codes.
-brandon
Old Jul 10, 2006 | 08:52 AM
phoenix's Avatar
John
what he said
Old Jul 10, 2006 | 05:49 PM
mike c.'s Avatar
i removed my a/c(no code ever)air system and front sway, i gained 1.9 tenths in the 1/4mi.
Old Jul 10, 2006 | 11:33 PM
snake charmer's Avatar
Thats not bad
Old Jul 11, 2006 | 01:43 AM
chrs1313's Avatar
i think the gain is due to the sway bar not the ac, it only weighs like 33 lbs and has basicly no drag on the motor when not turned on
Old Jul 11, 2006 | 09:03 AM
NOTFAST's Avatar
didnt throw a code...
Old Jul 11, 2006 | 09:10 AM
old and good's Avatar
perhaps but you are also taking weight of the car im not shure what the a/c weighs in full but its prolly 25lbs or even more not only is it making the car lighter but it is making the car lighter in the right place... that is the front
Old Jul 11, 2006 | 11:36 AM
chrs1313's Avatar
every 100 lbs is a tenth so 33 lbs is 0.033 of a difference in time, maybe .04 because off the front end so .19 tenths minus .04 is .15 tenths difference due to the sway bar (weight transfer) just my .02 though
Old Jul 14, 2006 | 03:40 PM
mike c.'s Avatar
well..with all added up i lost close to 60lbs off the nose. 33lbs-a/c,14lbs front sway and 12lbs air system. my car ram 1.9 tenths and was always 1.3-1.5 tenths faster all the time. when you take weight off the nose it helps more then taking more weight off else where. i've tried back to back track testing w/sway on and off....with it off it did'nt help much at all,so all the stuff off togeather helped alot.
