Drag Racing Tech
battery relocation write up?
Old Aug 3, 2006 | 11:58 AM
ls2 bait's Avatar
Default battery relocation write up?
anyone have a link to one? id like to know where to tap int the wirs and what was removed if anything from the engine bay as well as where u got the stuff to do it.
Old Aug 5, 2006 | 07:47 AM
ls2 bait's Avatar
t.t.t.
Old Aug 5, 2006 | 08:32 AM
blkbird_WS-6's Avatar
www.ws6.com/batt-relocate.htm Try that.
Old Aug 5, 2006 | 11:30 AM
00454sscamaro's Avatar
im going to make my own.
after i make the battery box etc. ill take pics.
im going to run the wires under the car , along with the nitrous lines. if the frame itself doesnt cover the wires/lines the whole way, im going to weld some tubing or something for the line and wire to go through. even though it would probly be easier to run the wires inside, as i removed my back seats-no use for them + all the trunk trim stuff. i just dont want to mess with the firewall. and i rather add weight at the lowest possible place.
Old Aug 6, 2006 | 03:51 PM
ls2 bait's Avatar
anyone else? acording to that write up ill need to replace all the existing wiring. is there no where i can tap into and just run it to the back?
Old Aug 6, 2006 | 08:57 PM
great421's Avatar
FYI -
I got a junction block from a car audio store, removed the portions that were post-maxifuse (2 of them), and then used those points to provide power to the "Hot at All Times" fuses. I mounted the block on the fan support, just above were the batery had been, then ran wires along the pass side to the trunk. That block really cleaned up the installation.
My $0.02 -
MIKE
Old Aug 7, 2006 | 10:19 AM
ls2 bait's Avatar
do u have any pics of what u r talking about?
Old Aug 10, 2006 | 08:09 PM
76LS1BIRD's Avatar
Restricted User
Check this out. Dale
https://ls1tech.com/forums/generation-iii-external-engine/388581-battery-relocation.html
