Drag Racing Tech
View Poll Results: a4, dr's do you have a line lock?
yes
51
38.64%
no
81
61.36%
Voters: 132. You may not vote on this poll
a4's at the track...
Old Aug 9, 2006 | 02:34 PM
Hennytime's Avatar
Default a4's at the track...
those of you auto guys who are track rats, when you use dr's ( i have bf's) do you use line locks to do a burnout? i couldnt get the wheels to spin last tiem at the track ( all my mods are a lid and cutout-321rwhp) on the dr's and a crappy track. so whats up?
Old Aug 9, 2006 | 02:45 PM
SEB's Avatar
SEB
I just back in to the waterbox & pull to the edge & hold the breaks & just nail it & burn the hides off em.
Old Aug 9, 2006 | 07:55 PM
JaSSon's Avatar
YES, YES, and YES. It will save your posi. Doing burnouts through the brakes will kill it.
Old Aug 10, 2006 | 08:16 AM
HaulinHawk's Avatar
TRU DAT!!!!
Old Aug 10, 2006 | 06:12 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Same here, M/T sportsman pros and no line lock. Pull to the edge of the box (I spin mine over slowly to make sure they're wet) and burnout.
The no line lock won't kill your posi, but it does eat the brakes up somewhat.
Derek
Old Aug 11, 2006 | 09:02 PM
Hennytime's Avatar
it seemed like i couldnt get the wheels to spin, in 1st gear, hitting the breaks as hard as possible, and then mashing the throttle...at osw
Old Aug 11, 2006 | 10:15 PM
7 Second Club
You don't want to mash the brakes as hard as possible. Just enough to keep the car from moving forward while you do the burnout. It takes a little practice but you'll get it. Make sure if you have traction control it's turned off (seems like a given but I've seen it happen) and make sure the tire is in the water (I go to the front edge of the box), and then spin to your heart's content (or until the tires get sticky, which mine do)!
Derek
Old Aug 11, 2006 | 10:56 PM
97blkz's Avatar
Huh? I back into the box , hold the brake, hit the gas , release the brake at 3 seconds and roll out of the box. I cut 1.5 60's on motor doing this!
Old Aug 13, 2006 | 05:26 PM
Unstang's Avatar
I have a line lock on the way, I think it will help quite a bit with the MT radials... I have trouble getting a consistent burnout.
Old Aug 21, 2006 | 04:41 PM
youngrigo's Avatar
When you get your tires in the water stop then let off the brakes for a split second let the car roll foward a little then press the brakes again while smashing on the gas. This tranfers the weight of the car off the back and to the front. lets you do a burnout pretty easy.
Old Aug 21, 2006 | 08:03 PM
ABA383's Avatar
I use the SLP line lock. It was an easy bolt in and made for very consistent burn outs...
--Alan
Old Aug 24, 2006 | 12:19 PM
badass02ss's Avatar
I do the same when I'm launching. I hold the brake just enough to keep the car from leaving, and just enough throttle to keep them from spinning!
Old Aug 24, 2006 | 12:20 PM
badass02ss's Avatar
Does that sound normal? Just curious, what is the best way to lauch an a4?
badass02ss's Avatar
I never tried shifting the weight. I know what I will be practicing next
Old Aug 30, 2006 | 09:39 AM
TwoFast4Lv's Avatar
I ran with out a LL for years. Then again I torn up more rear brake pads and rotors then I could afford at times The LL Cost less then a good set of brake pad's much less our expensice azz rotors
I got one from Jegs for $39.99 if I remember right
Old Aug 31, 2006 | 02:45 PM
calongo_SS's Avatar
I just replaced my warped rear rotors and installed a line lock. I'd just get the LL.
Old Sep 11, 2006 | 08:16 PM
gettinthere's Avatar
I have a line lock from SJM. It's probably one of the best little things I've put on my car.
Old Sep 12, 2006 | 01:59 AM
94z28L's Avatar
line lock will save the posi not to mention the rear brakes and transmission
Old Sep 12, 2006 | 03:53 PM
darrensls1's Avatar
I voted no because I don't have one. But from reading this thread, I may have to invest in one. I'll talk to Mike @ New Era Performace about installing one on my car. Thanks for this thread and the tips.
Old Sep 14, 2006 | 10:30 PM
Matt D's Avatar
Retired Street Racer
Same here. Get their ABS delete and linelock package. Can't beat it for the price.
