Drag Racing Tech
N2o and stall question.
Old Aug 14, 2006 | 01:30 AM
CrawlinWS6's Avatar
Import Patrol
Default N2o and stall question.
I thought this is a drag topic, so I am posting this here.
I am currently running a 150shot. I am wanting to up it to a 200 shot. I am running the basic nx efi wet kit. What would I need to do to run the 200 shot.
I know I will need to change out the jets (which one would I need). And will need to pull some timing. But what else would I need to do this?
Old Aug 15, 2006 | 11:07 PM
bjamick's Avatar
How bout your tranny is it rebuilt bc that will def be something that you want to do bc i already broke mine from a 100 shot. and also you will need a 5 pinion rear planetary for the tranny if you decide to rebuild it the rear planetary runs 1-2 gear so that will need to be very strong to hold up 2 a 200 shot of abuse sooo!! hope this helps you somewhat
Old Aug 16, 2006 | 06:30 AM
GM Muscle's Avatar
What are you running for fuel mods and is this just a bolt on car? You will deffinatly need a fuel pump and you will want to pull some more timing. I would also get the car on a wideband to make sure everything looks good.
If your an unbuilt auto not spraying through the shifts, it will be a toss up whether or not it breaks right away. I've sprayed my stock 4l60 for 4 years and it has seen about 40 passes with a 225 shot.
Old Aug 16, 2006 | 08:45 AM
bjamick's Avatar
man my 100 shot broke my tranny but i left on the bottle and stayed in it all the way, but i also have bout 108k miles on my car. only 2 passes on bottle broke something bc its slipping right now!
Old Aug 16, 2006 | 03:04 PM
GM Muscle's Avatar
With that many miles and spraying through the shifts, I'm not suprised it happened that quickly. It seems that high mile 4l60s won't hanle power nearly as well as a lower mile unit. Give it an overhaul with some good parts and hopefully it will be trouble free for you.
Old Aug 16, 2006 | 03:57 PM
bjamick's Avatar
ya i just bought a TCI pro racing rebuild kit for $350 from TCi and im buying a 5 pinion rear planetary to run 1st and 2nd gear so it should hold up, and when it shifts it will yank my head to the seat i hope and also about a 3500 stall will be going in it to so i def should be running really good after that.
Old Aug 17, 2006 | 02:27 PM
CrawlinWS6's Avatar
Import Patrol
I have a stage 3 4l60e, that has brought me to 11.04 so far. I'm a cammin, full bolt on etc. fuel upgrades are as follow. walbro intake pump, fast fuel rails, and 42lb injectors.
Old Aug 17, 2006 | 02:40 PM
GM Muscle's Avatar
I'm running a Walbro pump with 42lbs injectors (stock rails). With my cam and a 225 shot (crank rated), the Walbro alone wouldn't keep up. I was seeing about an 8-10 psi drop off the line and it wasn't recovering very well. I added a Hotwire kit and Voltage blaster which seemed to help but I suspect once I put a set of heads on the car I maybe back in the same boat again.
Old Aug 17, 2006 | 06:24 PM
CrawlinWS6's Avatar
Import Patrol
Is the 225 wet or dry?
Old Aug 17, 2006 | 07:04 PM
GM Muscle's Avatar
Both. Only a 50 dry.
