Pics of 315/60/15 MT DR's with mini-tubs
#81
Is a mini tub required to fit that tire? I have a rear that is narowed 3" per a side, and I run a race rim that is 5" bs, and there is plenty of room. My street rim has 4" bs, and the bulge of the tire barely sticks out. 4 1/2" would be perfect. Just wondering if I needed a mini with that tire on a 4" bs or 4 1/2"? Thanks.
#82
Originally Posted by JPMuscle
so you built a tubular front end or did you just tie the tubing into the origianl towers like most guys do, if not I need to see some pics of that
-thanks,
-john
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
-thanks,
-john
![](http://i27.photobucket.com/albums/c165/shady93z/P7010107-1.jpg)
#83
i believe Brady fit that size tire on a stock width axle, 15/10 prostar w/ 7.5" backspacing W/O minitubbing, only some slight cutting and the BFH to the inside of the wheelwell
9sec93, your car is awesome! that front area is very interesting
#84
Originally Posted by 9sec93
here is a pic of the front of my car. im not sure how much weight it saved but it sure does make it easy to work on. the only downfall is i cant put my tools there anymore.
Thats Friggin awesome, looks like im gonna have to talk with the chassis shop again in the morning
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Do you think regular street driving would have any adverse effects on a tubular front end such as that over time??
Very Cool,
-john
#85
i wouldnt think so. i plan on driving it on the street quite a bit. if its good enough for a race car i would think it would be good enough to cruise around the street on. i would think that the steel tubing would be as good as the sheetmetal (although pretty thick) strut tower especially since it ties into the bars coming down from the a-pillars. it is more triangulated than the strut tower attached to the thin firewall.
