Help with launching with an auto
just a quick question. what are common methods of launching with an automatic? I've heard of revving to about 3k and dropping the e-brakes or just simply flooring the car when the green hits.
Also, i'm going to the drags for the first time and my times are going to be awful, i'm prepared for it.. but i have really basic boltons, cai, bellows, lid and a magnaflow exhaust. what times should i be hitting ? thansk in advance. btw, i have a 2k z28.
If you're using street tires (non-drag radials), I'd bring the rpm's to 900-1000 (assuming stock convertor) while staying on the foot brake, then let go of the brake and roll into the throttle. Every street tire is different, but I found my best hooking was with my Good Year GSC's at 27 lbs in the rears (33-35 is what I normally daily drove them at) and 35-45 lbs in the fronts. I agree about no burnout, just a quick turning of them on dry land to clean them off. I always went around the water box and onto the track. Then backed up while looking behind me with door open to make sure I went back as far as possible until I saw the water patch and stop before getting there so still on dry pavement. Select 1st gear, bring revs up to 900-1000 rpm and hammer the gas hard (no brake holding here) to get the tires spinning and clean them. Then set myself square with the starting line and bump in to stage.
I cut a best of 2.00 60 foot time doing this. Drag radials are much more helpful and easier to launch WOT on instead of rolling/feathering the gas.
Good luck, and keep practicing!
Derek
now the next time i go, (later this year) i am going to try the brake rellease method, with 27lbs tire pressure rears, 33 fronts, 1/8 tank of gas, wieght reduction and hope i can get a 1.9 60' and improve on my 13.3 which i think will be very possible.
let us know hoe you do
ps. click on the 13.3 link in my sig to see my two launch's. hope this helps.
