Drag Racing Tech
pulling the wheels
Old 08-23-2006, 08:57 PM
cjg454ss's Avatar
Default pulling the wheels
whats the minimum setup you would need to pull the wheels and carry them a little. i have a 550 rwhp 02 auto camaro on nitrous with a 3600 converter. 4.10 rear is going in but i was thinking maybe bigger. also i run et street slicks, 26.5 tall. thanks for the help
Old 08-23-2006, 11:00 PM
DuronClocker's Avatar
LS1Tech 10 Year
I don't see how you can possibly have a problem. Have rear LCAs, PHB, and torque arm? I realize these aren't all necessary for that, but they definitely help. I also assume you have some sort of a bar/cage in the car if you have that kind of power to help with chassis rigidity. Reduce weight from the front if your tires grab but you are still having problems with pulling the wheels. Run skinnies, fiberglass hood, etc.
If you have trouble hooking up, step up to a 28" tall tire and see what happens then.
Old 08-24-2006, 12:54 PM
TWS
TWS's Avatar
I have 100 less RWHP in my '94 than you (NA, bottle is a different story ) with a SSF 3500 'verter and pull the wheels no problem. Work on suspension and lightening the front end.
Old 08-24-2006, 02:00 PM
Mike Comp T/A #57's Avatar
If the track is prepped with VHT you should be able to pull them.
V6 front springs will help.
Old 08-24-2006, 02:25 PM
Agt. Orange's Avatar
V6 springs wow i just got rid of mine cause when i would get on the car and let off the frame would smash on the ground.i DO NOT think V6 springs is a good idea they were very bad for me.
Old 08-24-2006, 02:49 PM
TWS
TWS's Avatar
I run V6 springs on the rear. My fronts (on my '94 at least) are stock, but I run QA-1's all the way around and they are usually on "1" up front for the track.
Whadda ya expect from a guy who races and beats on an ultra rare collector car?
Oh hi Mike.
<---- former owner of Comp T/A #8. Remember me?
Old 08-24-2006, 04:06 PM
n2o
n2o's Avatar
Make the front end lighter. Battery in the back, skinnies, washer tank, k-member, ac(if you can). Couple that with some stickies and viola.
Old 08-25-2006, 09:34 PM
brandonppr's Avatar
more ideas
!front swaybar
Qa1 drag shocks set to 1
you may need lighter springs for weight reductions maybe 275 or less
Old 08-25-2006, 09:55 PM
Zerskijpac's Avatar
just get my setup. see sig. its a hugguh orange transam (custom paint)
Old 08-25-2006, 10:10 PM
LS1TECH Sponsor
badpewter-z's Avatar
all in the correct suspension . you have plenty of power . shocks, control arms, drag bar(like the wolfe one) will help a ton and car will lancuh hard and straight every time.
with the right suspension setup and a little weight reduction up front you can get 350rwhp cars to lift
Old 08-25-2006, 10:38 PM
promod1955's Avatar
my cars stock internal, 330 rwhp, cuttin 1.52's and I yank them pretty good. its all in suspension setup. A wolfe or madman torque arm does wonders
Old 08-25-2006, 11:55 PM
1fast97gsx's Avatar
What rpms are you guys leaving at to pull the front wheels with that little power? ( 350 whp ) Is this on the street or at the track? Asphalt or concrete? What kind of tire?
Old 08-25-2006, 11:58 PM
promod1955's Avatar
foot breaking @ 2000 rpm at the track. first half of track is concrete. tire is a 26x11.50/15 et street
Old 08-26-2006, 08:19 AM
brandonppr's Avatar
2k rpm launch, 3600 stall, cam only tsp 231 237 ,26x11.50x17 ET Street, headers, 3" TD, LS6 intake, QA1 Drag shocks, LCA's, a few weight reductions, !front swaybar, batt relocation, 10 spoke SS wheels back and front, 3.23 gears in ten bolt, stock T Arm, All motor
I could lift them when I was running that set up
on the track, concrete
Old 08-26-2006, 10:12 PM
B18B1LS1's Avatar
I could pull my front tires a bit on my 17" Nittos at the track with MAYBE 350 rwhp on a good day. It's more about suspension than raw horsepower.
Old 08-27-2006, 01:31 AM
Havok2's Avatar
full bolt ons.
tunned
330 or so rwhp
ONLY lcas/sfc rest of suspenion STOCK.
check this out.....
