Drag Racing Tech
qa1's
Old Aug 30, 2006 | 11:09 PM
Blwn98z28's Avatar
Default qa1's
Just bought some QA1s with 275 lb spring what setting are you guys setting the shocks on front and rear? in auto cars.
thanks,
Jason
Old Aug 31, 2006 | 12:31 AM
Dmoney's Avatar
I have the fronts only and have them set at 4.
Old Aug 31, 2006 | 02:33 PM
jerflash's Avatar
fronts at 4 and rears at 6 but since you got such light springs in the front maybe a little tighter
Old Aug 31, 2006 | 09:02 PM
Mike Comp T/A #57's Avatar
Fronts on 1 and rear on 5.
Old Aug 31, 2006 | 09:31 PM
Blwn98z28's Avatar
thanks for the info.
I got the lighter spring because i drive the car on weekend and usually just to the track.DO you guys think that was to light of a spring?it said for drag use.
does anyone preload the front springs? if so how much like in inches how much did you preload them ?
Jason
Old Aug 31, 2006 | 10:20 PM
jerflash's Avatar
well what kinda wieght reduction do you have?
if you are full wieght then you will have to crank that spring allthe way up the shock to get the proper ride hight and it will be easier to bottem out on the street
now if you took a good amount of wieght off the front then no worries
Old Aug 31, 2006 | 11:35 PM
Blwn98z28's Avatar
that sucks because its a stock weight car but i am goin to remove some stuff here soon. what do you think i should remove from the front end?
thanks,
Jason
Old Sep 1, 2006 | 02:44 PM
jerflash's Avatar
idk man its a street car then there is mot much to do
bumper support, ac, k member, battery
it may be easier to go and get the heavier springs...for a full wieght auto car go with the 300 springs...straight from madmans mouth
i have a full wieght 6 speed car so i ahve the 325 springs
if you plan on doing some real wieght reduction then keep the 275s
Old Sep 1, 2006 | 04:13 PM
Blwn98z28's Avatar
alright thanks man. im goin to do alot soon just not at this moment so ill jsut buy the 300s and then keep the 275s for now and then switch back later. they were only like a 100$ so no biggie.
Jason
